- Construction machinery industry
- Rod head / bottom
Rod head / bottom
Arm drive component |
Hydraulic cylinder component
Material: TBH800 · S45C
Reducing setup changes through process integration
- Setup workload is reduced through process integration
- Using a sub-spindle, processes 1 and 2 can be completed on a single machine
- Turning and milling are performed on the same machine
- Thermo-Friendly Concept enables stable machining accuracy
- Stable machining accuracy is maintained even during long hours of continuous operation
