Machining complex-shaped components with a 5-axis machining center
- 5-Axis Auto Tuning System Ⅱ enables highly accurate simultaneous 5-axis machining
- Anyone can quickly and easily measure and compensate geometric errors, such as spindle axis misalignment
- In synergy with the Thermo-Friendly Concept,
accuracy of 5-axis machining is maintained over a long period of time
- Improved surface quality and significant reduction of machining time
- The tool tilt compensation function keeps the machining point consistent, ensuring a stable feed rate
- Surface quality is improved and finishing time is reduced
- Large machining area with a space-saving design
- Capable of handling components up to ø600 mm within the same footprint as a vertical machining center
