Process integration of turning process of large diameter parts and machining large diameter tapped holes
- High machining capacity that matches those of large lathes and machining centers
- Highly efficient machining of large diameter components
- Turning: 6.5 mm2 (S45C)
Milling capacity: 1,003 cm3/min (S45C) - Turning spindle max torque: 6,000 N-m
Milling tool spindle max torque: 505 N-m - machining diameter: ø1,200 mm
Highly efficient machining of large diameter components (referential video featuring alternate components)
- Highly efficient machining of large diameter tapped holes using a 5-axis vertical multitasking machine
- Large-diameter tapped holes are efficiently machined using helical machining, which involves moving the end mill in a spiral pattern along the Y-axis.
Helical machining operations
