- Construction machinery industry
- Large flange component
Drive component |
Wheel component
Material: S45C
Process-intensive machining of large complex-shaped components on a vertical multitasking machine
- Possible to machine a multi-sided shape workpiece in a single-chucking operation
- Processes such as turning, the drilling of vertical, horizontal, and angled holes, and surface machining using the Y-axis function can all be integrated into one machine.
- Stable chucking of thin heavy components
- Components are secured firmly under their own weight for stable chucking
- Distortion from clamping force is minimized, enabling high-accuracy machining even for thin components
- High-accuracy machining using in-process gauging
- Diameter measurement and compensation feedback are performed using the Y-axis stroke (1,000 mm), which matches the maximum machining diameter (ø1,200 mm)
