- Inverter parts Inverter case (e-Axle)
e-AxleInverter parts
Inverter case
Case component for inverter equipment
Material: Aluminum die cast
Non-cutting time is reduced to improve productivity
- High-speed machining and operation reduces non-cutting time of machine
- Rapid traverse X-axis, Y-axis, Z-axis: 60 m/min
- ATC time T-T: 1.0/1.3* C-C: 2.6/2.9*
(*: Tool weight is 4 kg or more)
- Efficiency is increased with machining time reduction function
- Cycle time is reduced for machining processes that frequently repeat rapid traverse and cutting feed, such as parts that need to be drilled many times. The cycle time is shortened by optimizing the acceleration rate according to machining requirements of the workpiece or machine condition.
