- Medical equipment industry
- Artificial knee joint
Minimizing boundary errors to reduce lead time for finishing process
- Minimizing boundary errors during indexed machining
Reducing lead time for finishing process -
- 5-axis machining centers have a complex axis configuration, making them prone to geometric errors. These geometric errors can be easily measured and compensated using the 5-Axis Auto Tuning System Ⅱ.
- Manual tuning effort is reduced.
- Boundary errors during indexed machining are minimized.
- Actual data of boundary errors: 3μm
- 5-axis machining centers can be installed within the same floor space as a 3-axis vertical machining center
- Compact 5-axis machining centers based on the structure of a 3-axis vertical machining center.
- Good access to the table allows setup to be conducted in a comfortable position.
