Process integration of large diameter hole drilling and side hole drilling
- Large diameter and inversed spot facing machining using a special head
- Efficient machining of large-diameter carrier holes using a special slim and long head while avoiding interference
- Helical machining with a special head and side cutter enables large-diameter inversed spot facing in the same process as carrier hole machining
Achieves large-diameter inversed spot facing with no phase shift from the carrier hole
- Highly efficient drilling of outer peripheral holes
- Outer peripheral holes drilled with high efficiency using NC-BC universal head
- With over 100 types of spindle-head attachments, one machine can handle components of any shape
- Long term high accuracy is maintained
- Changes in machine accuracy are diagnosed and visualized with an accuracy stability diagnosis function
The impact that changes in room temperature has on machine accuracy is visualized - The spatial accuracy of the machine is calibrated with 3D Smart Calibration System
Regular inspections and calibrations of machine accuracy maintain high accuracy over the long term and ensure the reliability of measurement and machining processes
