Turning on a machining center, turning slopes on a multitasking machine
Turning done with a rotary tool spindle.
Turning with tilting axis machining consolidated in
machining centers and multitasking machines.
- Production floor issues
- Turning of unbalanced work
is difficult -
- ・To turn an unbalanced workpiece on a lathe, a special setup and a dedicated machine are necessary.
- ・On a machining center, the diameter for each hole made requires a certain tool, which may not be available.
- User benefits
- Consolidating turning
without dedicated machine -
- ・Turning processes for unbalanced workpieces (tapering, end facing) can be consolidated.
- ・Hole making with different diameters — with one tool.
- ・Machine IDs/ODs with ATC-oversized large tool diameters.
The Turn-Cut Guide app makes it easy to set cutting conditions
A Turn-Cut Guide app* will assist your input of cutting conditions based on machining diameters and tool information, to easily calculate the required spindle speed and the circularity you want.
* A feature mainly for machining centers.
