Okuma Technology Premium Solutions
Premium Solutions
Auto machining data compensation, easy and improved die/mold surface quality
Hyper-Surface
Hyper-Surface, in addition to the Sculptured-Surface Adaptive Acceleration Control featured in the
previous Super-NURBS, detects CAM-output machining data “disturbance,” and corrects that on the
Okuma CNC to improve surface quality while maintaining the required shape accuracy.
  1. Production floor issues
    Machining data command-point
    disturbance adversely affects
    surface quality
    • ・Machining data variations result in scratches on the machined surface.
    • ・Correcting the supplied data is difficult.
    • ・Removing cutter marks by hand finishing and polishing is time consuming.
  2. User benefits
    Better surface quality without modifying the machining data
    • ・Eliminates the time required for hand finishing.
    • ・Reduce scratches and uneven edges.
Eliminating variations in command position and feed rate improve machined surface quality
Automatically corrects for small variations in machining data command positions of output from a CAM processor.
And passing speeds for each cutter path at corners are made consistent.
That stabilizes feed rates and improves surface quality.
Conditions Tool Spindle
speed
[min-1]
Feed rate
[mm/min]
Pick feed
[mm]
Cutting
depth
[mm]
Scan-line
machining
ø10-mm ball
end mill
15,000 6,000 0.2 0.1
Hyper-Surface ON / OFF
Aligning adjacent cutter paths, reducing ridges
Correcting uneven spaces between adjacent cutter paths, and reducing inconsistent valley depths and edge widths.
Tool Spindle speed
[min-1]
Spindle feed rate
[mm/min]
Pick feed[mm] Depth of cut
[mm]
ø30-mm ball
end mill
10,000 5,000 0.5 0.1
