- Technology & Solutions Premium Solutions
- C-axis Torque Skip
Easy and automatic phase matching
Here is how to get C-axis zero offsets: by mounting a stopper on the turret,
and having it contact a keyway or notch, to read the C-axis torque fluctuations.
- Production floor issues
- Fixtures and gauging required
blank material phase matching -
- ・A cutting reference for a phase direction requires phase matching for each workpiece.
- ・Phase adjusting required when mounting blanks, causes accuracy variances per operator setup.
- ・We can’t buy expensive in-process gauging just for doing zero offsets.
- User benefits
- Easy phase setting without
measuring devices -
- ・Eliminate fixture- and operator-related mount errors.
- ・Eliminate fixture-related phase matching.
- ・Eliminate in-process gauging.
Auto phase settings by the stopper contacting the cutting reference
C-axis zero offsets can be set in-machine by having the stopper contact the cutting reference. When a workpiece has a keyway, reciprocating CW/CCW rotation will index the C-axis zero offset position by the load on the C axis.
